P1605
Manufacturer Specific Definitions for P1605
Buick | CAN data bus -AlC |
Cadillac | CAN data bus –NC |
Chevrolet | CAN data bus -A/C |
Citroen | Keep Alive Memory Test Failure |
Daewoo | Vacuum Solenoid V/V |
Ford | PCM Keep Alive Memory Test Error Conditions |
Gm | Loss Of HVAC Serial Data Conditions |
Honda | CAN data bus |
Hyundai | Internal Control Module Read Only Memory(ROM) Error(IFB) |
Infiniti | AT diagnosis communication -signal failure |
Land Rover | Power interuption in KAM |
Lexus | Knock control – malfunction |
Lincoln | ‘Keep alive’ memory test failure |
Mazda | Engine control module (ECM) -keep alive test error |
Mercedes-Benz | Acceleration sensor,” ESP/ASR system -rough road signal, comparison of wheel speeds |
Mercury | Engine control module (ECM)/transmission control module (T<;:M) communication error |
Nissan | TCM diagnosis communication line – malfunction |
Oldsmobile | CAN data bus -A/C |
Opel | Engine control module (ECM) - coding |
Peugeot | Keep Alive Memory Test Failure |
Scion | Engine Stall History |
Toyota | Knock control - malfunction |
Volvo | CAN data bus, ETS – CAN data bus OFF |
We have not gotten around to publishing a technical guide specifically for P1605 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
