P1601
Manufacturer Specific Definitions for P1601
Audi | Engine control module (ECM) - supply voltage |
Buick | Serial Communication Malfunction |
Cadillac | Engine control module (ECM) -temperature high |
Chevrolet | CAN data bus, ECM/ASSITCS/instrumentation control module/diagnostic control module some communication lost |
Citroen | ECM/TCM Serial Communication Error |
Daewoo | Engine control module (ECM)/transmission control module (TCM) – serial peripheral communication malfunction |
Daihatsu | Keyless communication(code disaccord¡¢communication error) |
Gmc | CAN data bus, engine control module (ECM)/ anti lock brake system (ABS)/traction control system (TCS)/instrumentation control module/ diagnostic control module some communication lost |
Gm | CAN data bus, engine control module (ECM)/ anti lock brake system (ABS)/traction control system (TCS)/instrumentation control module/ diagnostic control module some communication lost |
Honda | Integrated motor assist – system malfunction |
Hyundai | ECU ‘L’ Line |
Isuzu | Serial communication – malfunction |
Kenworth | P1601 - Customer data area checksum failure |
Mazda | ECM to AT communication – signal error |
Mitsubishi | ECM to throttle control unit – communication malfunction |
Oldsmobile | Data bus -circuit malfunction |
Opel | Module temperature switch,ECM - temperature high |
Peterbilt | P1601 - Customer data area checksum failure |
Peugeot | ECM/TCM Serial Communication Error |
Pontiac | CAN data bus, engine control module(ECM)/antilock brake system (ABS)/traction control system (TCS)/instrumentation control module/diagnostic control module -not allmodules communicating |
Porsche | Voltage Supply |
Saturn | CAN data bus, engine control module (ECM)I antilock braking system (ABS)/traction control system (TCS)/instrumentation control moduleldiagnostic control module some communication lost |
Suzuki | Engine control module (ECM), CAN data bus – communication malfunction |
Toyota | Injector Correction Circuit Malfunction |
Volvo | Electronic throttle system (ETS), throttle motor – circuit malfunction |
Volkswagen | Engine control module (ECM) - supply voltage |
