P1600
BAT Team
Manufacturer Specific Definitions for P1600
AudiEngine control module (ECM) - supply voltage low from ignition switch
BuickEngine control module (ECM) -programming/ memory
CadillacEngine control module (ECM) -malfunction
ChevroletEngine control module (ECM) -malfunction
ChryslerCAN data bus, rough road signal -signal error
CitroenLoss of KAM Power; Open Circuit
DaewooEcu K Line Mal (Serial Comm)
DaihatsuKeyless communication(ECU abnormal)
DodgeAmbient air temperature sensor -high input
EagleCAN data bus, TCM -circuit malfunction
FordLoss of KAM Power Open Circuit
FreightlinerAmbient air temperature sensor -high input
GeoPCM Battery Circuit Fault
GmcEngine control module (ECM) -malfunction
GmEngine control module (ECM) -malfunction
HondaIntegrated motor assist system malfunction
HummerEngine control module (ECM) -malfunction
HyundaiSerial Communication-Malfunction (With A/T)
IsuzuSerial communication - malfunction
LexusEngine control module (ECM) -supply voltage
MazdaEngine control module (ECM) – KAM error
MitsubishiAT to ECM – signal failure
OldsmobileEngine control module (ECM)
OpelEngine control module (ECM) - program error
PeugeotLoss of KAM Power; Open Circuit
PontiacEngine control module  (EeM) – malfunction
PorscheVoltage Supply
SaabEngine control module (ECM) – malfunction
SaturnEngine control module (ECM) -malfunction
ScionECM BATT Malfunction
SuzukiEngine control module (ECM)/transmission control module (TCM) – signal failure
ToyotaEngine control module (ECM) - supply voltage
VolvoElectronic throttle system (ETS) – malfunction
VolkswagenEngine control module (ECM) - supply voltage low from ignition switch
We have not gotten around to publishing a technical guide specifically for P1600 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
