P1589
Manufacturer Specific Definitions for P1589
Acura | Brake booster pressure sensor – signal malfunction |
Audi | AC/heater air temperature control switch - short to ground |
Bmw | WT overload protection, ECU temperature – high input, bank 1 |
Citroen | TCU Unable To Control Desired Throttle Angle |
Ford | Throttle Control Unit Unable To Control Desired Throttle Angle |
Honda | Motor power inverter module – current signal problem |
Mercedes-Benz | Engine control module (ECM), bank 2, knock control – defective |
Peugeot | TCU Unable To Control Desired Throttle Angle |
Toyota | Acceleration Sensor Learning Value |
Volvo | Electronic throttle system (ETS) – range/performance problem |
Volkswagen | AC/heater air temperature control switch - short to ground |
