P1585
Reading P1585 on your car
P1585 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1585
BmwWT sensor circuit malfunction – no input, bank 2
BuickCruise control system -inhibit output circuit
CadillacCruise control system -inhibit output circuit
ChevroletCruise control system, inhibit output circuit
CitroenThrottle Control Unit Malfunction
FordThrottle Control Unit Malfunction
GmCruise Control Inhibit Output Circuit Conditions
HondaBrake fluid pressure sensor B – circuit range/performance problem
OldsmobileCruise control system -inhibit output circuit
PeugeotThrottle Control Unit Malfunction
PontiacCruise control system, inhibit output circuit
PorscheMisfire With Empty Fuel Tank
We have not gotten around to publishing a technical guide specifically for P1585 yet.
