P1582
Reading P1582 on your car
P1582 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1582
AudiIdle speed adaptation - limit reached
BmwVVT limp home mode, bank 1 – mass air flow (MAF) signal malfunction
BuickCruise Control Module Direction Low Input Conditions
CadillacCruise Control Module Direction Low Input Conditions
ChevroletCruise Control Module Direction Low Input Conditions
CitroenElectronic Throttle Monitor Data Available
FordElectronic Throttle Monitor Data Available
GmCruise Control Module Direction Low Input Conditions
HondaMotor current U phase signal circuit – high input
JaguarElectronic Throttle Monitor Data Available
LincolnEngine control module (ECM) -throttle data stored
MercuryEngine control module (ECM) -throttle data stored
PeugeotElectronic Throttle Monitor Data Available
SaturnCruise control system, direction circuit -voltage low
VolkswagenIdle speed adaptation - limit reached
We have not gotten around to publishing a technical guide specifically for P1582 yet.
