P1576
Manufacturer Specific Definitions for P1576
Audi | Engine mounting control solenoid, Bank 1 - short to ground |
Bmw | VVT control motor, bank 2 supply voltage circuit malfunction |
Buick | Brake Booster Vacuum Sensor Circuit High Voltage |
Cadillac | Brake boost vacuum sensor voltage high |
Chevrolet | Brake Booster Vacuum Sensor Circuit High Voltage |
Citroen | Pedal Position Not Available |
Ford | Accelerator Pedal Position Sensor Signal Malfunction |
Gm | Brake Booster Vacuum Sensor Circuit High Input Conditions |
Honda | Motor driver module – voltage malfunction |
Jaguar | Accelerator Pedal Position Sensor Signal Malfunction |
Lincoln | Accelerator Pedal Position Sensor Signal Malfunction |
Mercury | Accelerator Pedal Position Sensor Signal Malfunction |
Peugeot | Pedal Position Not Available |
Saab | Brake pedal position (BPP) switch – open circuit/short to positive |
Subaru | Engine control module (ECM) – EEPROM error |
Volkswagen | Engine mounting control solenoid, short to ground |
