P1575
Reading P1575 on your car
P1575 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1575
AudiEngine mounting control solenoid, Bank 1 - short to positive
BuickBrake pedal position (BPP) switch -extended travel
CadillacBrake pedal position (BPP) switch -extended travel contacts -voltage high
ChevroletBrake pedal position (BPP) .switch. extended travel contacts -voltage high
CitroenPedal Position Out of Self Test Range
FordPedal Position Out of Self Test Range
GmExtended Travel Brake Switch Circuit Conditions
HondaMotor power inverter module – voltage malfunction
LexusCruise control/skid control warning buzzer- malfunction
LincolnPedal Position Out of Self Test Range
MercuryPedal Position Out of Self Test Range
OldsmobileBrake pedal position (BPP) switch -extended travel contacts -voltage high
PeugeotPedal Position Out of Self Test Range
PontiacBrake pedal position (BPP) switch, extended travel contacts -voltage high
ToyotaCruise control/skid control warning buzzer – malfunction
VolkswagenEngine mounting control solenoid, short to positive
We have not gotten around to publishing a technical guide specifically for P1575 yet.
