P1574
Reading P1574 on your car
P1574 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1574
BuickStop Lamp Switch Circuit
CadillacBrake pedal position (BPP) switch -voltage high
ChevroletBrake pedal position (BPP) switch, voltage high
CitroenThrottle Position Sensor Disagreement btwn Sensors
FordStop Lamp Switch Circuit
GmcBrake pedal position (BPP) switch, voltage high
GmStop Lamp Switch Circuit
HondaHybrid battery pack – temperature signal circuit malfunction
InfinitiCruise control vehicle speed sensor – signal malfunction
IsuzuBrake pedal position (BPP) switch – circuit malfunction
MazdaThrottle position (TP) sensor – signal correlation
MitsubishiEngine control module (ECM) – malfunction
NissanCruise control vehicle speed sensor – signal variation between two vehicle speed sensors
OldsmobileBrake pedal position (BPP) switch -voltage high
PeugeotThrottle Position Sensor Disagreement btwn Sensors
PontiacBrake pedal position (BPP) switch, voltage high
SaabStop lamp switch – signal error
SaturnCruise control brake pedal switch -voltage high
SubaruImmobilizer control module – communication error
VolvoThrottle position (TP) sensor – signal correlation
We have not gotten around to publishing a technical guide specifically for P1574 yet.
