P1572
Manufacturer Specific Definitions for P1572
Audi | Engine mounting control solenoid, Bank 2 - short to ground |
Buick | ASR Active Circuit Low Too Long |
Cadillac | ASR Active Circuit Low Too Long |
Chevrolet | Traction control system (TCS). active signal -malfunction |
Chrysler | Brake pedal position (BPP) switch -circuit malfunction |
Citroen | Brake Pedal Switch Circuit Malfunction |
Dodge | Brake pedal position (BPP) switch -circuit malfunction |
Ford | Brake Pedal Switch Circuit Malfunction |
Gm | Traction Control System - Circuit Low Too Long Conditions |
Honda | Motor driver module – temperature signal circuit high |
Hyundai | Cruise Control System-Vehicle Speed lower than target speed |
Infiniti | Cruise control brake pedal switch – circuit malfunction |
Jeep | Brake pedal position (BPP) switch -circuit malfunction |
Kenworth | P1572 - Post Compressor temperature plausibility fault |
Land Rover | Brake pedal position (BPP) switch – circuit malfunction |
Lexus | Cruise control laser radar sensor – improper aiming of beam axis |
Lincoln | Brake pedal position (BPP) switch -circuitintermittent |
Mazda | Brake pedal position (BPP) switch – circuit malfunction |
Mercury | Brake pedal position (BPP) switch -circuit intermittent |
Mitsubishi | Brake Pedal Switch Circuit Malfunction |
Nissan | Cruise control brake switch – circuit malfunction |
Opel | Engine control module (ECM) / Immobilizer control module - no Immobilizer signal |
Peterbilt | P1572 - Post Compressor temperature plausibility fault |
Peugeot | Brake Pedal Switch Circuit Malfunction |
Pontiac | Traction control system (TCS), active signal malfunction |
Ram | Brake pedal position (BPP) switch -circuit malfunction |
Saab | Immobilizer control module/ECM – circuit malfunction |
Subaru | Immobilizer control module/ECM – circuit malfunction |
Toyota | Improper Aiming Of Radar Sensor Beam Axis |
Volvo | Brake pedal position (BPP) switch – range/performance problem |
Volkswagen | Engine mounting control solenoid, short to ground |
