P1566
Manufacturer Specific Definitions for P1566
Audi | AC compressor, load signal - implausible signal |
Buick | Cruise Control System Engine RPM Too High |
Cadillac | Cruise control -engine speed too high |
Chevrolet | Cruise Control System Engine RPM Too High |
Citroen | Speed Control Command Switch Out of Range Low |
Ford | Speed Control Command Switch Out of Range Low |
Gm | Engine RPM Too High - Cruise Control Disabled Conditions |
Honda | Motor commutation sensor -signal problem |
Hyundai | Analog Battery Sensor Circuit |
Kenworth | P1566 - Idle diagnostic fuel error fault |
Lexus | Cruise control switch – circuit malfunction |
Lincoln | Cruise control system |
Mazda | Transmission control module (TCM) – battery voltage low |
Mercury | Cruise control system |
Oldsmobile | Cruise control -engine speed too high |
Peterbilt | P1566 - Idle diagnostic fuel error fault |
Peugeot | Speed Control Command Switch Out of Range Low |
Scion | Cruise Control Main Switch Circuit Malfunction |
Toyota | Cruise Control Main Switch Circuit Malfunction |
Volkswagen | AC compressor, load signal - implausible signal |
