P1565
Manufacturer Specific Definitions for P1565
Alfa Romeo | Cruise control master switch - signal malfunction |
Audi | Throttle control unit - lower stop not reached |
Bmw | WT control motor, bank 2 – supply voltage high input |
Buick | Cruise control servo position sensor -circuit malfunction |
Cadillac | Cruise Servo Position Sensor |
Chevrolet | Cruise control servo position sensor -circuit malfunction |
Citroen | Speed Control Command Switch Out of Range High |
Ford | Speed Control Command Switch Out of Range High |
Gm | Cruise Servo Position Sensor Fault |
Honda | Motor commutation signal problem |
Kenworth | P1565 - Idle diagnostic speed error fault |
Lexus | Cruise control switch – circuit malfunction |
Lincoln | Cruise control system |
Mazda | Cruise control system |
Mercury | Cruise control system |
Mini | Camshaft Position Actuator 'B' Control Open Circuit Bank 1 |
Oldsmobile | Cruise control servo position sensor -circuit malfunction |
Peterbilt | P1565 - Idle diagnostic speed error fault |
Peugeot | Speed Control Command Switch Out of Range High |
Pontiac | Cruise control servo position sensor -circuitmalfunction |
Scion | Cruise Control Main Switch Circuit Malfunction |
Toyota | Cruise control switch - signal malfunction |
Volkswagen | Throttle control unit - lower stop not reached |
