P1555
Reading P1555 on your car
P1555 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1555
| Make | Fault Location |
| Alfa Romeo | Brake pedal position (BPP) switch - signal malfunction |
| Audi | Turbocharger (TC) pressure - upper limit exceeded |
| Buick | Electronic Variable Orifice Output |
| Cadillac | Electronic Variable Orifice Output |
| Chevrolet | Electronic Variable Orifice Output |
| Daewoo | Idle Co Poten. Open / Short |
| Gm | Electronic Variable Orifice Fault Conditions |
| Honda | Hybrid battery pack temperature sensor 2 – signal circuit low input |
| Hyundai | Idle CO Potentiometer Open/Short |
| Lexus | Reactor Temperature Sensor Circuit Low |
| Opel | Throttle posi6on (TP) sensor A / mass air flow (MAF) sensor - implausible signal |
| Porsche | Charge Pressure Characteristics |
| Saturn | Electronic variable orifice -circuit malfunction |
| Toyota | Reactor Temperature Sensor Circuit Low |
| Volvo | Engine control relay – signal malfunction |
| Volkswagen | Turbocharger (TC) pressure - upper limit exceeded |
We have not gotten around to publishing a technical guide specifically for P1555 yet.
