P1553
Manufacturer Specific Definitions for P1553
Audi | Manifold absolute pressure (MAP) sensor/ barometric pressure (BARO) sensor - range/performance problem |
Bmw | VVT control circuit, bank 1 – high input |
Daewoo | Isc Actuator(Close) - Open |
Honda | Hybrid battery pack temperature sensor 1 – signal circuit low input |
Hyundai | ISC Actuator (Close)-Open |
Infiniti | Battery condition sensor – signal too high |
Lamborghini | Idle air control valve opening coil high voltage |
Land Rover | Idle air control (lAC) valve closing coil -circuit high |
Mini | Crankshaft Exhaust Camshaft Correlation |
Nissan | Electrical load sensor – circuit malfunction |
Porsche | Idle Air Control Valve |
Volkswagen | Manifold absolute pressure (MAP) sensor/ barometric pressure (BARO) sensor - range/performance problem |
