P1532
Reading P1532 on your car
P1532 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1532
AudiIdle control - lean running speed below specification
BmwWT control motor, bank 1 – position circuit malfunction
BuickA/C Evaporator Temperature Sensor Circuit Low Voltage
CadillacA/C Evaporator Temperature Sensor Circuit Low Voltage
ChevroletAlC refrigerant temperature sensor -voltage low
CitroenIMCC Circuit Malfunction, Bank B
FordIntake Manifold Communication Control Circuit Bank 2
GmA/C Evaporative Temp Sensor Circuit Low Input Conditions
HyundaiElectronic Throttle Control System Malfunction Throttle Valve Stuck
JaguarIntake Manifold Communication Control Circuit Bank 2
MazdaIntake Manifold Communication Control Circuit Bank 2
MiniCamshaft Position Actuator 'B' Control Open Circuit Bank 2
PeugeotIMCC Circuit Malfunction, Bank B
PontiacAlC refrigerant temperature sensor -voltage low
SaabAccelerator pedal position (APP) sensor   1 & 2 – short circuit
VolkswagenIdle control - lean running speed below specification
We have not gotten around to publishing a technical guide specifically for P1532 yet.
