P1531
BAT Team
Manufacturer Specific Definitions for P1531
Alfa RomeoAC compressor clutch relay - circuit malfunction
AudiCamshaft position (CMP) actuator - open circuit
BmwVVT self-test – no value, bank 2
BuickLow AlC refrigerant charge
CadillacA/C Low Side Temperature Sensor Fault
ChevroletA/C refrigerant pressure sensor -voltage low
CitroenInvalid Test - Accelerator Pedal Movement
FordInvalid Test Accelerator Pedal Movement
GmLow Air Conditioning Refrigerant Charge Conditions
MiniCamshaft Position Actuator 'B' Control Open Circuit Bank 1
OldsmobileLow AlC refrigerant charge
PeugeotInvalid Test - Accelerator Pedal Movement
PontiacNC refrigerant pressure sensor -voltage low
PorscheCamshaft Adjustment Bank 1
SaabAccelerator pedal position (APP) sensor 1 & 2 – adapted value out of range
VolkswagenCamshaft position (CMP) actuator - open circuit
We have not gotten around to publishing a technical guide specifically for P1531 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
