P1530
Manufacturer Specific Definitions for P1530
Audi | Camshaft position (CMP) actuator - short to ground |
Bmw | VVT self-test – out of range, bank 2 |
Buick | AlC refrigerant pressure sensor -circuit malfunction |
Cadillac | Throttle position motor -circuit malfunction |
Chevrolet | A/C refrigerant pressure sensor/switch -circuitmalfunction |
Citroen | A/C Clutch Circuit Malfunction |
Daewoo | Max. Vehicle Speed Limit Flt |
Daihatsu | A/C evaporator temperature sensor |
Ford | Open or Short to A/C Compressor Clutch Circuit |
Geo | Ignition Timing Adjustment Switch Circuit |
Gm | Ignition Timing Adjustment Switch Circuit Conditions |
Hyundai | Maximum Vehicle Speed Limiting-Malfunction |
Lincoln | Ale compressor clutch -circuit malfunction |
Mini | Idle Air Control Actuator 2 Target Position Fault |
Mitsubishi | A/C control module – circuit malfunction |
Oldsmobile | AlC refrigerant pressure sensor, circuit malfunction |
Opel | AC cut - off relay - circuit malfunction |
Peugeot | A/C Clutch Circuit Malfunction |
Pontiac | NC refrigerant pressure sensor/switch -circuit malfunction |
Porsche | Camshaft Adjustment Bank 1 |
Saab | Accelerator pedal position (APP) sensor 1 & 2 – range/performance problem |
Saturn | Throttle control system -malfunction |
Suzuki | Ignition timing adjustment connector – circuit malfunction |
Volkswagen | Camshaft position (CMP) actuator - short to ground |
We have not gotten around to publishing a technical guide specifically for P1530 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
