P1527
Manufacturer Specific Definitions for P1527
Audi | Camshaft position (CMP) actuator, Bank 1 - short to ground |
Bmw | WT supply voltage circuit malfunction – low input, bank 2 |
Buick | Throttle Position Sensor Learned Closed Throttle Degrees Out Of-Range |
Cadillac | Transmission range (TR) switch/transmission fluid pressure (TFP) switch -signal variation |
Chevrolet | Throttle Position Sensor Learned Closed Throttle Degrees Out Of-Range |
Citroen | Accelerate Warmup Solenoid Circuit Malfunction |
Daewoo | Sensor Supply Pwr 2 Fault |
Gm | Throttle Position Sensor Learned Closed Throttle Degrees Out Of-Range |
Hyundai | Sensor Supply Voltage 2-Malfunction |
Mazda | Bypass air solenoid valve – short/open circuit |
Mini | Camshaft Position Actuator 'A' Control Circuit Signal Low Bank 1 |
Peugeot | Accelerate Warmup Solenoid Circuit Malfunction |
Volkswagen | Camshaft position (CMP) actuator, short to ground |
