P1526
Manufacturer Specific Definitions for P1526
Audi | Camshaft position (CMP) actuator, Bank 1 - short to positive |
Bmw | WT supply voltage circuit malfunction – high input, bank 2 |
Buick | Minimum Throttle Position Not Learned Conditions |
Cadillac | Minimum throttle position not leamed |
Chevrolet | Minimum Throttle Position Not Learned Conditions |
Citroen | Air Bypass System |
Daewoo | Sensor Supply Pwr 1 Fault |
Gm | Minimum Throttle Position Not Learned Conditions |
Hyundai | Sensor Supply Voltage 1-Malfunction |
Kenworth | P1526 - CM1 000986 out of range fault |
Mazda | Supercharger air control solenoid (vent) – short/open circuit |
Mini | Camshaft Position Actuator 'A' Control Open Circuit Bank 2 |
Oldsmobile | Minimum throttle position not learned |
Opel | Electronic throttle system (ETS),adaptation - malfunction |
Peterbilt | P1526 - CM1 000986 out of range fault |
Peugeot | Air Bypass System |
Saturn | Throttle control unit -replaced or flat battery |
Volvo | Engine control module (ECM) – malfunction |
Volkswagen | Camshaft position (CMP) actuator, short to positive |
We have not gotten around to publishing a technical guide specifically for P1526 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
