P1524
Manufacturer Specific Definitions for P1524
Audi | Fuel pump relay - open circuit/short to ground |
Bmw | WT supply voltage circuit malfunction – high input, bank 1 |
Buick | Throttle Closed Position Performance |
Cadillac | Throttle pOSition (TP) sensor -leamed closed throttle angle |
Chevrolet | Throttle Closed Position Performance |
Chrysler | Oil Pressure Out Of Range Camshaft Advance / Retard Disable |
Citroen | Variable Intake Solenoid System |
Dodge | Oil Pressure Out Of Range Camshaft Advance / Retard Disable |
Gm | TP Sensor Learned Closed Throttle Degrees Out-Of-Range |
Honda | Brake booster pressure sensor – range/ performance problem |
Hyundai | Sensor Supply Voltage 2-Low Input |
Jeep | Oil Pressure Out Of Range Camshaft Advance / Retard Disable |
Kenworth | P1524 - Fault data for the oil system pressure low monitor |
Mazda | Charge air cooler bypass solenoid valve – malfunction |
Oldsmobile | Throttle position (TP) sensor -learned closed throttle angle |
Peterbilt | P1524 - Fault data for the oil system pressure low monitor |
Peugeot | Variable Intake Solenoid System |
Porsche | Camshaft Adjustment Bank 2 |
Volkswagen | Fuel pump relay - open circuit/short to ground |
We have not gotten around to publishing a technical guide specifically for P1524 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
