P1523
Manufacturer Specific Definitions for P1523
Acura | Brake Booster Pressure Sensor Circuit High Voltage |
Audi | SRS crash signal received |
Bmw | WT sensor circuit – implausible sensor data, bank 2 |
Buick | Electronic Throttle Control Throttle Return |
Cadillac | Throttle position motor -closed position performance |
Chevrolet | Throttle control unit, closed throttle position -performance |
Citroen | IVC Solenoid Circuit Malfunction |
Genesis | Throttle control system – lower stop not reached |
Gmc | Throttle control unit, throttle position during battery saving mode |
Gm | Throttle Closed Position Performance |
Honda | Brake booster pressure sensor – circuit malfunction, high voltage |
Hyundai | ETC Throttle Position Sensor Position Reset Malfunction |
Isuzu | Throttle position motor – closed position performance |
Kenworth | P1523 - Oil pressure too high |
Kia | Electronic throttle system (ETS)- malfunction |
Lamborghini | VICS solenoid valve circuit fault |
Mazda | Intake manifold air control solenoid – circuit malfunction |
Mini | Camshaft Position Actuator 'A' Signal Low Bank 1 |
Oldsmobile | Throttle control unit, throttle position during battery saving mode |
Opel | Electronic throttle system (ETS) - malfunction |
Peterbilt | P1523 - Oil pressure too high |
Peugeot | IVC Solenoid Circuit Malfunction |
Pontiac | Throttle control unit, closed throttle position -performance |
Saab | Throttle actuator control (TAC) system- range/performance problem |
Saturn | Throttle control unit, .closed throttle position -performance |
Volkswagen | SRS crash signal received |
Geely SL P1523
