P1522
Manufacturer Specific Definitions for P1522
Acura | Brake Booster Pressure Sensor Circuit Low Voltage |
Audi | Camshaft position (CMP) control, Bank 2 - malfunction |
Bmw | VVT sensor circuit – implausible sensor data, bank 1 |
Buick | Park/Neutral To Drive/Reverse At High RPM |
Cadillac | Park/Neutral To Drive/Reverse At High RPM |
Chevrolet | Park/Neutral to Drive/Reverse at High RPM |
Citroen | Variable Intake Solenoid #2 Circuit Malfunction |
Daewoo | Battery Fault |
Gm | Park/Neutral to Drive/Reverse at High RPM |
Honda | Brake booster pressure sensor – circuit malfunction, low voltage |
Hyundai | Battery |
Land Rover | Engine control module (ECM)/ABS control module – communication malfunction |
Mazda | Intake manifold air control solenoid 2 – short/open circuit |
Mercedes-Benz | Camshaft position (CMP) control, bank 2 – mechanical fault |
Mini | Camshaft Position Actuator 'A' Bank 2 |
Peugeot | Variable Intake Solenoid #2 Circuit Malfunction |
Volkswagen | Camshaft position (CMP) control, malfunction |
We have not gotten around to publishing a technical guide specifically for P1522 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
