P1520
BAT Team
Manufacturer Specific Definitions for P1520
AudiIntake manifold air control solenoid 2 - open circuit
BmwWT sensor circuit, solenoid loss, bank 1
BuickPark/neutral position (PNP) switch
CadillacPark/neutral position (PNP) switch/transmission range (TR) switch
ChevroletPark/neutral position (PNP) switch -circuit malfunction
CitroenIntake Manifold Runner Control Circuit Malfunction
DaewooAlternator Field Coil Sig Mal
DaihatsuSwitch signal system
DodgeCruise control master switch -malfunction
FordIntake Manifold Runner Control Circuit Fault
FreightlinerCruise control master switch -malfunction
GeoStop Lamp Switch Circuit
GmcPark/neutral position (PNP) switch -circuit malfunction
GmPark Neutral Position Switch Circuit Conditions
HyundaiGenerator FR Terminal-Malfunction.
IsuzuPark/neutral position (PNP) switch – circuit malfunction
Land RoverIntake manifold air control system – circuit malfunction
LexusStop lamp switch – signal malfunction
LincolnIntake manifold runner control (IMRC) module -circuit malfunction
MazdaIntake manifold air control -circuit malfunction
MercuryIntake manifold runner control (IMRC) module -circuit malfunction
MiniCamshaft Position Actuator 'B' Bank 1
OldsmobilePark/neutral position (PNP) switch
OpelElectronic throttle system (ETS) - supply voltage
PeugeotIntake Manifold Runner Control Circuit Malfunction
PontiacPark/neutral position (PNP) switch -circuitmalfunction
SaabEngine coolant blower motor relay 1 – voltage high
SubaruEngine coolant blower motor relay 1 – voltage high
ToyotaStop lamp switch - signal malfunction
VolvoAccelerator pedal position (APP) sensor – implausible signal
VolkswagenIntake manifold air control solenoid 2 - open circuit
We have not gotten around to publishing a technical guide specifically for P1520 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
