P1519
BAT Team
Manufacturer Specific Definitions for P1519
AcuraIdle air control (IAC) valve - circuit failure
AudiCamshaft position (CMP) control, Bank 1 - malfunction
BmwWT control circuit – reset malfunction, bank 1
BuickThrottle Actuator Control Module Internal Circuit
CadillacThrottle position motor -circuit malfunction
ChevroletThrottle motor position sensor 1 -signal malfunction
ChryslerCruise Control Front Distance Sensor Lens Cracked Missing
CitroenIntake Manifold Runner Control (Stuck Closed)
FordIntake Manifold Runner Control Fault Stuck Closed
GmThrottle Actuator Control Module Internal Circuit Conditions
HondaIdle air control (lAC) valve – circuit failure
IsuzuIdle air control (IAC) valve - circuit failure
KenworthP1519 - DEFOI urea level warning fault (1st threshold)
Land RoverIntake manifold air control system – valve stuck closed
LincolnIntake manifold runner control (IMRC) module -malfunction, stuck closed
MazdaIntake manifold air control – stuck closed
Mercedes-BenzCamshaft position (CMP) control, bank 1 – mechanical fault
MercuryIntake manifold runner control (IMRC) module -malfunction, stuck closed
MiniInlet Camshaft Control System End Position Plausibility
PeterbiltP1519 - DEFOI urea level warning fault (1st threshold)
PeugeotIntake Manifold Runner Control (Stuck Closed)
PontiacThrottle motor position sensor 1 -signalmalfunction
SaturnEngine control module (ECM), throttle actuator control -output driver malfunction
VolkswagenCamshaft position (CMP) control, malfunction
We have not gotten around to publishing a technical guide specifically for P1519 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
