P1515
Manufacturer Specific Definitions for P1515
Audi | Intake manifold air control solenoid 1 - short to ground |
Bmw | WT control circuit, solenoid loss, bank 1 |
Buick | Control Module Throttle Actuator Position Performance |
Cadillac | Throttle command/actual throttle position signal variation |
Chevrolet | Throttle command/actual throttle position -signalvariation |
Citroen | Electric Current Circuit Malfunction |
Gmc | Throttle command/actual throttle position -signal variation |
Gm | Control Module Throttle Actuator Position Performance |
Honda | Throttle command/actual throttle position - signal variation |
Hummer | Throttle command/actual throttle pOSition – signal variation |
Hyundai | Oil Temperature Sensor - Abnormal |
Isuzu | Throttle command/actual throttle position – signal vpriation |
Kenworth | P1515 - DEFOI EGR system category fault |
Lamborghini | A/T to M/T codification |
Mini | System Time Plausibility |
Oldsmobile | Throttle command/actual throttle position -signal variation |
Opel | Idle air control (IAC) valve - circuit malfunction |
Peterbilt | P1515 - DEFOI EGR system category fault |
Peugeot | Electric Current Circuit Malfunction |
Pontiac | Throttle command/actual throttle position -signalvariation |
Porsche | Intake Manifold Resonance Flap |
Saab | Idle air (lAC) control valve, circuit 3 – voltage high |
Saturn | Throttle command/actual throttle position signal variation |
Subaru | Idle air (lAC) control valve, circuit 3 – voltage high |
Volkswagen | Intake manifold air control solenoid 1 - short to ground |
