P1512
Manufacturer Specific Definitions for P1512
Alfa Romeo | Idle speed control (ISC) - malfunction |
Audi | Intake manifold air control solenoid 1 - short to positive |
Bmw | WT limp home mode – high input |
Chevrolet | Throttle control unit -signal variation |
Citroen | Intake Manifold Runner Control (Bank 1) Stuck Closed |
Daewoo | Idle speed control (ISC) actuator- malfunction |
Ford | Intake Manifold Runner Control Input Error Bank 1 |
Gmc | Throttle command/actual throttle position -signals out of range |
Gm | Throttle command/actual throttle position -signals out of range |
Hyundai | Engine Coolant Temperature Sensor - Low |
Isuzu | Throttle control unit – signal variation |
Jaguar | Closed throttle position (CTP) switch - low input |
Land Rover | Intake manifold air control system, bank 1 – valve stuck closed |
Lincoln | Intake manifold runner control (IMRC) module -malfunction, stuck closed (bank 1) |
Mazda | Intake manifold air control – stuck close |
Mercury | Intake manifold runner control (IMRC) module -malfunction, stuck closed (bank 1) |
Mini | DISA Control Circuit Signal Low |
Oldsmobile | Throttle control unit -signal variation |
Peugeot | Intake Manifold Runner Control (Bank 1) Stuck Closed |
Saab | Idle air (lAC) control valve, circuit 2 – voltage low |
Saturn | Throttle control unit -signal variation |
Subaru | Idle air (lAC) control valve, circuit 2 – voltage low |
Suzuki | Main Throttle Idle Actuator Malfunction |
Toyota | Turbocharger (TC) pressure - too high |
Volkswagen | Intake manifold air control solenoid 1 - short to positive |
