P1509
Manufacturer Specific Definitions for P1509
Acura | Idle air control (IAC) system - high RPM |
Audi | Idle air control (IAC) valve - circuit malfunction |
Bmw | ECM self-test – idle air control (lAC) system fault |
Buick | Idle Speed High Idle Air Control System Not Responding |
Cadillac | Idle air control (lAC) valve -high rpm |
Chevrolet | Idle air control (lAC) valve -high rpm |
Citroen | Idle Control System Circuit Shorted |
Daewoo | Mps - Signal High |
Dodge | Leak Detection Pump Switch or Mechanical Fault |
Gmc | Idle air control (lAC) valve -high rpm |
Gm | Idle Speed High Idle Air Control System Not Responding |
Honda | IAC Valve Circuit Failure |
Hyundai | MPS – High |
Isuzu | Idle air control (lAC) system – high RPM |
Jaguar | Idle air control (IAC) valve - circuit malfunction |
Land Rover | Idle air control (lAC) valve opening coil – malfunction |
Mazda | Idle air control (lAC) valve 2 – short/open circuit |
Mini | Idle Speed Control Valve Opening Solenoid Control Circuit Electrial |
Oldsmobile | Idle air control (lAC) valve -rpm high |
Opel | Idle air control (IAC) valve - circuit malfunction |
Peugeot | Idle Control System Circuit Shorted |
Pontiac | Idle air control (lAC) valve -high rpm |
Saturn | Idle air control (lAC) valve, rpm high |
Volkswagen | Idle air control (IAC) valve - circuit malfunction |
We have not gotten around to publishing a technical guide specifically for P1509 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
