P1508
Manufacturer Specific Definitions for P1508
Acura | Idle air control (IAC) system - low RPM |
Audi | Idle speed control (ISC) - upper limit reached |
Bmw | ECM self-test- idle air control (lAC) system fault |
Buick | Idle Speed Low Idle Air Control System Not Responding |
Cadillac | Idle air control (lAC) valve -low rpm |
Chevrolet | Idle air control (lAC) valve -low rpm |
Chrysler | Ambient/Battery Temperature Sensor Volts Too Low |
Citroen | Idle Control System Circuit Open |
Daewoo | Mps - Signal Low |
Dodge | Ambient/Battery Temperature Sensor Volts Too Low |
Genesis | Idle air control (lAC) valve – closing coil circuit – short circuit |
Gmc | Idle air control (lAC) valve -low rpm |
Gm | Idle Speed Low Idle Air Control System Not Responding |
Honda | Idle air control (lAC) valve – circuit failure |
Hyundai | Idle Speed Control Actuator Signal High of Coil #2 |
Isuzu | Idle air control (lAC) system – low RPM |
Jaguar | Idle air control (IAC) valve - circuit malfunction |
Kia | Idle air control (lAC) valve – closing coil signal high |
Land Rover | Idle air control {lAC) valve -circuit malfunction |
Lexus | PTC AC Auxiliary Heater Disabled High |
Mazda | Idle air control (lAC) valve 1 – short/open circuit |
Mini | Idle Speed Control Valve Opening Solenoid Control Open Circuit |
Oldsmobile | Idle air control (lAC) valve -rpm low |
Opel | Idle air control (IAC) valve - circuit malfunction |
Peugeot | Idle Control System Circuit Open |
Pontiac | Idle air control (lAC) valve -low rpm |
Ram | Crankcase pressure sensor range/performance |
Saturn | Idle air control (lAC) valve, rpm low |
Volkswagen | Idle speed control (ISC) - upper limit reached |
