P1507
Reading P1507 on your car
P1507 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1507
AudiIdle speed control (ISC) - lower limit reached
BmwECM self-test – accelerator pedal position ·(APP) monitoring fault
CitroenIdle Air Control Underspeed Error
DaewooMps - Range / Performance Mal
FordIdle Air Control Under Speed Error
GenesisIdle air control (lAC) valve – closing coil circuit – open circuit
HyundaiIdle Speed Control Actuator Signal Low of Coil #2
JaguarIdle air control (IAC) valve - RPM higher than expected
KiaIdle air control (lAC) valve – closing coil signal low
Land RoverIdle air control (lAC) – value low
LexusPTC AC Auxiliary Heater Disabled Low
LincolnIdle air control (lAC) valve -under-speed error
MazdaIdle air control (lAC) system – underspeed error
MercuryIdle air control (lAC) valve -under-speed error
MiniIdle Speed Control Valve Open Solenoid Control Circuit Signal Low
MitsubishiIdle air control (lAC) valve – RPM higher than expected
PeugeotIdle Air Control Underspeed Error
RamCrankcase pressure sensor range/performance
SaabIdle air (lAC) control system – malfunction
SubaruIdle air (lAC) control system – malfunction
VolkswagenIdle speed control (ISC) - lower limit reached
We have not gotten around to publishing a technical guide specifically for P1507 yet.
