P1506
Manufacturer Specific Definitions for P1506
Audi | Closed throttle position (CTP) switch - does not open |
Bmw | ECM self-test – speed monitoring reset |
Citroen | Idle Air Control Overspeed Error |
Daewoo | Mps |
Ford | Idle Air Control Overspeed Error |
Genesis | Idle air control (lAC) valve – opening coil circuit – short circuit |
Hyundai | Idle Speed Control Actuator Signal High of Coil #1 |
Jaguar | Idle air control (IAC) valve - RPM lower than expected |
Kia | Idle air control (lAC) valve – opening coil signal high |
Land Rover | Idle air control (lAC) – value high |
Lincoln | Idle air control (lAC) valve -over-speed error |
Mazda | Idle air control {lAC) system – overspeed error |
Mercury | Idle air control (lAC) valve -over-speed error |
Mini | Idle Speed Control Valve Open Solenoid Control Circuit Signal High |
Mitsubishi | Idle air control (lAC) valve – RPM lower than expected |
Peugeot | Idle Air Control Overspeed Error |
Ram | Crankcase pressure sensor range/performance |
Volkswagen | Closed throttle position (CTP) switch - does not open |
