P1505
Manufacturer Specific Definitions for P1505
Acura | Positive Crankcase Ventilation Air Leakage |
Audi | Closed throttle position (CTP) switch - does not close |
Bmw | ECM self-test – throttle position (TP) monitoring fault |
Chrysler | Vehicle Speed Output Circuit High |
Citroen | Idle Air Control System At Adaptive Clip |
Dodge | Vehicle Speed Output Circuit High |
Ford | Idle Air Control System at Adaptive Clip |
Genesis | Idle air control (lAC) valve – opening coil circuit – open circuit |
Honda | Intake system – leak detected |
Hyundai | Idle Speed Control Actuator Signal Low of Coil #1 |
Kenworth | P1505 - Vehicle speed sensor frequency |
Kia | Idle air control (lAC) valve -opening coil signal low |
Land Rover | Idle air control (lAC) |
Lincoln | Idle air control (lAC) system -air trim, at limit |
Mazda | Idle air control {lAC) system |
Mercury | Idle Air Control System at Adaptive Clip |
Mini | Idle Speed Control Valve Closing Solenoid Control Circuit Electrial |
Peterbilt | P1505 - Vehicle speed sensor frequency |
Peugeot | Idle Air Control System At Adaptive Clip |
Saab | Idle air (lAC) control valve – voltage high |
Subaru | Idle air (lAC) control valve – voltage high |
Volkswagen | Closed throttle position (CTP) switch - does not close |
