P1502
Manufacturer Specific Definitions for P1502
Audi | Fuel pump relay - short to positive |
Bmw | Time out control module – output bus |
Buick | Theft Deterrent Fuel Enable Signal Not Received |
Cadillac | Immobilizer control module -fuel enable signal |
Chevrolet | Theft Deterrent Fuel Enable Signal Not Received |
Chrysler | Vehicle over-speed condition -front axle speed greater than rear axle |
Citroen | Vehicle Speed Sensor Intermittent Malfunction |
Dodge | Vehicle over-speed condition -front axle speed greater than rear axle |
Ford | Vehicle Speed Sensor Intermittent |
Genesis | Battery sensor – charge circuit low |
Gm | Theft Deterrent System Signal Not Received Conditions |
Hyundai | Wheel Speed Sensor Circuit |
Jeep | Vehicle over-speed condition -front axle speed greater than rear axle |
Kenworth | P1502 - Vehicle speed pulse width modulated mark space ratio |
Kia | Battery Not Charging |
Lincoln | Vehicle speed sensor (VSS) -intermittent signal |
Mazda | Vehicle speed sensor (VSS) – signal malfunction |
Mercury | Vehicle speed sensor (VSS) -intermittent signal |
Mini | Idle Speed Control Valve Closing Solenoid Control Circuit Signal High or Low |
Mitsubishi | Vehicle Speed Sensor 1/2 Correlation Non Drive Wheels |
Opel | Immobilizer control module - no signal) |
Peterbilt | P1502 - Vehicle speed pulse width modulated mark space ratio |
Peugeot | Vehicle Speed Sensor Intermittent Malfunction |
Porsche | Fuel Pump Relay End-Stage |
Ram | Vehicle over-speed condition -front axle speed greater than rear axle |
Saab | Engine coolant blower motor – malfunction |
Subaru | Engine coolant blower motor – malfunction |
Volkswagen | Fuel pump relay - short to positive |
