P1496
Manufacturer Specific Definitions for P1496
Chrysler | Engine control module (ECM) -5 volt output low |
Dodge | Engine control module (ECM) -5 volt output low |
Eagle | Manifold absolute pressure (MAP) sensor 5 volt output low |
Jeep | Engine control module (ECM) -5 volt output low |
Kenworth | P1496 - System fault has caused the system to go into PM mode and close EGR valve. |
Kia | Exhaust gas recirculation (EGR) valve – circuit 1 malfunction |
Mazda | Exhaust gas recirculation (EGR) valve’coil 1 – short/open circuit |
Mitsubishi | 5 Volt Supply Output Too Low |
Peterbilt | P1496 - System fault has caused the system to go into PM mode and close EGR valve. |
Plymouth | Engine control module (ECM) -5 volt output low |
Ram | Engine control module (ECM) -5 volt output low |
Saab | Exhaust gas recirculation (EGR) solenoid valve – signal 3 – voltage low |
Subaru | Exhaust gas recirculation (EGR) solenoid valve – signal 3 – voltage low |
