P1493
P1493 | Low Pressure Pump For Brake Power Too Low (AUDI, VOLKSWAGEN) Battery Temperature Sensor Signal Too Low Condition (CHRYSLER, DODGE, JEEP, MITSUBISHI) EVAP Canister Purge Control Valve/Solenoid Valve Stuck Open (INFINITI, NISSAN) Evaporative Emission Pressure Sensor / Fuel Tank Level Sensor In Fuel Tank - Range / Performance Problem / Malfunction (SAAB) EGR Signal Line 1 Circuit High (SUBARU) |
Other Manufacturer Specific Definitions for P1493
Low Pressure Pump For Brake Power Too Low (Volkswagen)Low Pressure Pump For Brake Power Too Low (Audi)
Ambient/battery temperature sensor -voltage low (Chrysler)
Ambient/battery temperature sensor -voltage low (Dodge)
Ambient/battery temperature sensor -voltage low (Eagle)
Evaporative emission (EVAP) canister purge control valve - malfunction (Infiniti)
Ambient/battery temperature sensor -voltage low (Jeep)
Evaporative emission (EVAP) canister purge valve -malfunction, stuck open (Mercury)
Battery Temperature Sensor Signal Too Low Condition (Mitsubishi)
Evaporative emission (EVAP) canister purge system – control valve malfunction (Nissan)
Ambient/battery temperature sensor -voltage low (Plymouth)
Evaporative emission (EVAP) pressure sensor/fuel tank level sensor, in fuel tank – signal too high when depressurized/ malfunction (Saab)
Exhaust gas recirculation (EGR) solenoid valve – signal 1 – voltage high (Subaru)
Ошибка P1493 авто Кенго 2 2013 року випуску 1,5 дци, неможливо прочитати помилку
