P1490
Manufacturer Specific Definitions for P1490
Audi | EVAP Canister Purge Regulator Valve 2 Short To Ground |
Chrysler | Engine coolant blower motor relay |
Citroen | Secondary Air Relief Solenoid Circuit Malfunction |
Dodge | Engine coolant blower motor relay -low speed |
Eagle | Engine coolant blower motor relay -low speed |
Infiniti | Evaporative emission (EVAP) canister purge control system – malfunction |
Jeep | Engine coolant blower motor relay, low speed -wiring open/short circuit |
Kenworth | P1490 - EGR valve stuck open |
Mercedes-Benz | Evaporative emission (EVAP) canister purge valve(s)- defective |
Mercury | Evaporative emission (EVAP) canister purge valve bypass solenoid |
Mitsubishi | Low Speed Radiator Fan Control Relay Condition |
Nissan | Evaporative emission (EVAP) canister purge system – bypass vacuum valve malfunction |
Peterbilt | P1490 - EGR valve stuck open |
Peugeot | Secondary Air Relief Solenoid Circuit Malfunction |
Plymouth | Engine coolant blower motor relay |
Saab | Thermostat – malfunction |
Subaru | Thermostat – malfunction |
Volkswagen | EVAP Canister Purge Regulator Valve 2 Short To Ground |
