P1484
Manufacturer Specific Definitions for P1484
Audi | Secondary Air Injection Pump Relay 2 Electrical Circuit Malfunction |
Buick | Cooling Fan RPM Signal Malfunction |
Cadillac | Cooling Fan RPM Signal Malfunction |
Chevrolet | Cooling Fan RPM Signal Malfunction |
Citroen | Open Power To Ground VCRM |
Dodge | Trans Fan Relay Circuit |
Ford | Open Power Ground To Variable Load Control Module |
Gmc | Engine coolant fan speed/engine speed -signal variation |
Gm | Cooling Fan RPM Signal Malfunction |
Isuzu | Engine coolant blower motor relay – speed signal variation |
Jeep | Catalytic converter -overheating |
Kenworth | P1484 - EGR CAN sensor current too high |
Lincoln | Variable load control module -malfunction |
Oldsmobile | Engine cooling fan system -maximum fan speed tolerance exceeded |
Peterbilt | P1484 - EGR CAN sensor current too high |
Peugeot | Open Power To Ground VCRM |
Ram | Diesel particulate filter (DPF) temperature toohigh |
Volkswagen | Secondary Air Injection Pump Relay 2 Electrical Circuit Malfunction |
