P1483
Manufacturer Specific Definitions for P1483
Audi | Secondary Air Injection Pump Relay 2 Short To Ground |
Buick | Engine cooling system -performance |
Cadillac | Engine cooling system -performance |
Chevrolet | Engine cooling system -performance |
Citroen | Power To Fan Circuit Overcurrent |
Dodge | Battery Temperature Sensor Volts Out of Limit |
Ford | Power to Cooling Fan Exceeded Normal Draw |
Gm | Engine Cooling System Performance Conditions |
Jeep | Catalytic converter temperature sensor, high input -wiring short circuit to positive |
Kenworth | P1483 - EGR CAN sensor command timeout |
Land Rover | Leak detection pump - heater circuit |
Lincoln | Engine coolant blower motor -intermittent fault |
Oldsmobile | Engine cooling system -performance |
Opel | Engine coolant blower motor relay 3 - malfunction |
Peterbilt | P1483 - EGR CAN sensor command timeout |
Peugeot | Power To Fan Circuit Overcurrent |
Pontiac | Engine cooling system -performance |
Volkswagen | Secondary Air Injection Pump Relay 2 Short To Ground |
We have not gotten around to publishing a technical guide specifically for P1483 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
