P1480
Manufacturer Specific Definitions for P1480
Buick | Cooling Fan 1 Control Circuit High |
Cadillac | Cooling Fan 1 Control Circuit High |
Chevrolet | Cooling Fan 1 Control Circuit High |
Chrysler | PCV Solenoid Circuit Condition |
Citroen | Fan Secondary Low with Low Fan On |
Dodge | Glow plug control module -voltage supply fault |
Ford | Fan Secondary Low With Low Fans On |
Freightliner | Glow plug control module -voltage supply fault |
Gm | Cooling Fan 1 Control Circuit High |
Infiniti | Engine coolant blower motor control – circuit malfunction |
Jeep | Positive crankcase ventilation (PCV) solenoid -wiring open/short circuit |
Kenworth | P1480 - EGR CAN sensor has permanent governor deviation |
Lincoln | Engine coolant blower motor (low speed) with lowspeed fan ON |
Mazda | Cooling fan – circuit malfunction |
Nissan | Engine coolant blower motor control – circuit malfunction |
Peterbilt | P1480 - EGR CAN sensor has permanent governor deviation |
Peugeot | Fan Secondary Low with Low Fan On |
Saab | Engine coolant blower motor relay 1 – voltage high |
Subaru | Engine coolant blower motor relay 1 – voltage high |
Volvo | Engine coolant blower motor control module – signal low |
We have not gotten around to publishing a technical guide specifically for P1480 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
