P1475
Reading P1475 on your car
P1475 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1475
AudiEVAP Control System LDP Malfunction/Signal Circuit Open
BmwThrottle position control – control deviation, bank 1
CitroenFan Relay (Low) Circuit Malfunction
DodgeEGR Valve Position
JeepEngine control module (ECM) -auxiliary 5 voltoutput high
MazdaCooling fan – circuit malfunction
MiniLeakage Diagnostic Pump Reed Switch Did Not Close
PeugeotFan Relay (Low) Circuit Malfunction
RamEngine control module (ECM) 1 -auxiliary 5 volt output high
VolkswagenEVAP Control System LDP Malfunction/Signal Circuit Open
We have not gotten around to publishing a technical guide specifically for P1475 yet.
