P1462
Manufacturer Specific Definitions for P1462
Audi | Exhaust gas recirculation temperature (EGRT) control, Bank 2 - range/performance problem |
Bmw | Map Cooling Thermostat Control Circuit Signal Low |
Chrysler | Fuel Level Output Circuit Low |
Citroen | A/C pressure sensor circuit voltage high |
Dodge | Engine coolant temperature (ECT) sensorimplausible signal |
Ford | Air Conditioning Pressure Sensor Circuit Low |
Freightliner | Engine coolant temperature (ECT) sensorimplausible signal |
Land Rover | AJC refrigerant pressure sensor – high input |
Lincoln | AlC refrigerant pressure sensor -low voltage |
Mazda | A!C refrigerant pressure sensor – low voltage |
Mercury | AlC refrigerant pressure sensor -low voltage |
Mini | Heated Catalyst Internal Control Module Checksum/ROM Error |
Peugeot | A/C pressure sensor circuit voltage high |
Volkswagen | Exhaust gas recirculation temperature (EGRT) control, range/ performance problem |
We have not gotten around to publishing a technical guide specifically for P1462 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
