P1460
Manufacturer Specific Definitions for P1460
Acura | Fuel Level Sensor Power Supply Circuit |
Audi | Exhaust gas recirculation temperature (EGRT) control, Bank 2 - control limit reached |
Bmw | Charging system – battery discharged |
Buick | Cooling Fan Control System |
Cadillac | Misfire -low fuel level |
Chevrolet | Cooling Fan Control System |
Citroen | Wide open throttle A/C cutoff relay circuit |
Ford | Wide Open Throttle Air Conditioning Cutoff Circuit Malfunction |
Geo | Cooling Fan Control System Fault |
Gm | Cooling Fan Control System Fault Conditions |
Honda | Fuel Level Sensor Power Supply Circuit |
Lincoln | Wide open throttle (WOT) relay, AlC -circuit malfunction |
Mazda | Wide open throttle (WOT) air conditioning cut off- circuit malfunction |
Mercury | Wide open throttle (WOT) relay, AlC -circuit malfunction |
Mini | Heated Catalyst Heater Power Switch Temperature Sensor Electrical Bank 2 |
Peugeot | Wide open throttle A/C cutoff relay circuit |
Saab | Immobilizer activated – incorrectly programmed/not programmed |
Suzuki | Engine coolant blower motor – system malfunction |
Volkswagen | Exhaust gas recirculation temperature (EGRT) control, control limit reached |
