P1454
Manufacturer Specific Definitions for P1454
Acura | Fuel Tank Pressure Sensor Range/Performance Problem |
Audi | Exhaust gas recirculation temperature (EGRT) sensor 1/Bank 1 - short to ground |
Bmw | Charging system – voltage low |
Citroen | Evaporative System Vacuum Test Malfunction |
Honda | Fuel tank pressure sensor – circuit range/performance |
Jeep | Diesel particulate filter (DPF) pressure differential sensor -flow too high |
Mini | Secondary Air Injection Pump With Series Resistor Control Circuit Electrical |
Peugeot | Evaporative System Vacuum Test Malfunction |
Volkswagen | Exhaust gas recirculation temperature (EGRT) short to ground |
We have not gotten around to publishing a technical guide specifically for P1454 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
Pozdrav.
Na koje probleme kod renaulta kangoo maxi, 2015 diesel 1.5 dci ukazuje dijagnostička šifra 1454?
Hvala
