P1449
Manufacturer Specific Definitions for P1449
Audi | Catalyst Temperature Sensor 2 Circuit Open/Short to B+ |
Bmw | Engine oil pressure – mechanical control solenoid sticking deactivated |
Citroen | Evaporative Check Solenoid Circuit Malfunction |
Ford | EVAP System Unable To Hold Vacuum |
Honda | Hybrid battery pack – deterioration |
Kia | Evaporative emission {EVAP) canister purge valve – circuit malfunction |
Lamborghini | Canister drain cut valve solenoid circuit fault |
Mazda | Evaporative emission (EVAP) canister purge system – tank pressure problem |
Mini | Diagnostic Module Tank Leakage Pump Too High |
Peugeot | Evaporative Check Solenoid Circuit Malfunction |
Suzuki | EVAP Purge Control Valve Malfunction Stuck Closed |
Volkswagen | Catalyst Temperature Sensor 2 Circuit Open/Short to B+ |
We have not gotten around to publishing a technical guide specifically for P1449 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
