P1446 – EVAP Canister Vent Control Valve Close (Chevrolet Captiva)
Manufacturer Specific Definitions for P1446
Audi | Catalyst Temperature Circuit Short To Ground |
Bmw | Oil quality sensor – temperature error |
Citroen | Evaporative Vac Solenoid Circuit Malfunction |
Honda | Hybrid battery pack – individual voltage input deviation |
Infiniti | Evaporative emission (EVAP) canister purge control valve – malfunction |
Kia | Evaporative emission (EVAP) leak detection module solenoid – circuit malfunction |
Mazda | Evaporative emission (EVAP) system |
Mercury | Evaporative emission (EVAP) canister purge valve -remains closed |
Mini | Diagnostic Module Tank Leakage Pump Control Circuit Signal High |
Nissan | Evaporative emission (EVAP) canister purge system – vent control valve malfunction |
Peugeot | Evaporative Vac Solenoid Circuit Malfunction |
Saab | Evaporative emission (EVAP) atmospheric pressure solenoid – voltage low |
Subaru | Evaporative emission (EVAP) canister purge valve – voltage low |
Volkswagen | Catalyst Temperature Circuit Short To Ground |
We have not gotten around to publishing a technical guide specifically for P1446 – EVAP Canister Vent Control Valve Close (Chevrolet Captiva) yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
Tengo este problema con un chevrolet Captiva 2007, segunda vez que pasa, la luz vuelve a aparecer al borrarla, pero con el tiempo se quita, sin borrarla
P1446 valvula de veltilacion de evap cerrada
Tengo una Chevrolet captiva 2008 petrolera, aqui no sale que significa este código
I have a Chevrolet captiva 2007 that I’m getting this code on so didn’t help me really
A co było zepsute kolego..? Mi też wyświetla ten kod
Yo tengo el mismo problema pero aún no puedo saber de qué se trata
Stesso errore codice e non so come risolvere
