P1444
Manufacturer Specific Definitions for P1444
Audi | Exhaust gas recirculation (EGR) valve position sensor - range/performance problem |
Bmw | Random/multiple cylinder(s) - misfire detected |
Citroen | Purge Flow Sensor Circuit Low Input |
Ford | Purge Flow Sensor Circuit Input Low |
Honda | High voltage short circuit |
Infiniti | Evaporative emission (EVAP) canister purge control system – malfunction |
Jaguar | EVAP Canister Purge Control System |
Lexus | Secondary air injection (AIR) switching valve, valve stuck open, bank 2 – circuit malfunction |
Lincoln | Evaporative emission (EVAP) system -low input |
Mazda | Evaporative emission (EVAP) canister purge flow sensor – low input |
Mercedes-Benz | Catalytic converter temperature sensor, bank 2 – defective |
Mercury | Evaporative emission (EVAP) system -low input |
Mini | Diagnostic Module Tank Leakage Pump Control Open Circuit |
Nissan | Evaporative emission (EVAP) canister purge system – control valve malfunction |
Peugeot | Purge Flow Sensor Circuit Low Input |
Saab | Evaporative emission (EVAP) system – open circuit/short to ground |
Scion | Secondary Air Injection System Switching Valve Stuck Open Bank 2 |
Toyota | Secondary Air Injection System Switching Valve Stuck Open Bank 2 |
Volkswagen | Exhaust gas recirculation (EGR) valve position sensor - range/performance problem |
