P1442
Manufacturer Specific Definitions for P1442
Acura | Evaporative emission (EVAP) canister purge system - vacuum switch malfunction |
Audi | Exhaust gas recirculation (EGR) valve position sensor - high input |
Bmw | Oil pump circuit – low voltage |
Buick | Evaporative emission (EVAP) system vacuum switch -circuit malfunction |
Cadillac | EVAP Vacuum Switch High Voltage During Ignition On |
Chevrolet | Evaporative emission (EVAP) system vacuum switch -circuit malfunction |
Citroen | Evaporative Emission Control System Leak Detected |
Ford | EVAP System Small Leak Detected |
Gmc | Evaporative emission (EVAP) system vacuum switch -circuit malfunction |
Gm | EVAP Purge Solenoid Switch Static Test Conditions |
Honda | Evaporative emission (EVAP) canister purge system - vacuum switch malfunction |
Infiniti | Evaporative emission (EVAP) canister purge system – small leak |
Isuzu | Evaporative emission (EVAP) canister purge switch – voltage high |
Land Rover | Evaporative emission (EVAP) system – leak detected |
Lexus | Secondary air injection (AIR) switching valve, valve stuck closed, bank 1 – circuit malfunction |
Lincoln | Evaporative emission (EVAP) system -small leakdetected |
Mazda | Evaporative emission (EVAP) system – system leak detected |
Mercury | EVAP System Small Leak Detected |
Nissan | Evaporative emission (EVAP) canister purge system – small leak |
Oldsmobile | Evaporative emission (EVAP) system vacuum switch -circuit malfunction |
Peugeot | Evaporative Emission Control System Leak Detected |
Pontiac | Evaporative emission (EVAP) system vacuumswitch -circuit malfunction |
Saab | Evaporative emission (EVAP) system/fuel tank level sensor – small leak detected/malfunction |
Scion | Stuck Closed In Secondary Air Injection Vacuum Switching Valve Bank 1 |
Subaru | Fuel level sensor- range/performance problem |
Toyota | Stuck Closed In Secondary Air Injection Vacuum Switching Valve Bank 1 |
Volkswagen | Exhaust gas recirculation (EGR) valve position sensor - high input |
Hola,quiero saber que significa p1442 para peugeot 307 sw
