P1429
Reading P1429 on your car
P1429 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1429
| Make | Fault Location |
| Audi | Vacuum pump, brakes - open circuit |
| Citroen | Electric Air Pump Primary Failure |
| Honda | Motor driver module – overheating signal circuit problem |
| Peugeot | Electric Air Pump Primary Failure |
| Volkswagen | Vacuum pump, brakes - open circuit |
We have not gotten around to publishing a technical guide specifically for P1429 yet.
