P1420
Manufacturer Specific Definitions for P1420
Acura | NOx Adsorptive Catalyst System Efficiency Below Threshold |
Audi | Secondary air injection (AIR) valve/solenoid - circuit malfunction |
Bmw | Camshaft Position Actuator 'A' Control Open Circuit Bank 1 |
Buick | Intake Air Low Pressure Switch Circuit Low Voltage |
Cadillac | Intake Air Low Pressure Switch Circuit Low Voltage |
Chevrolet | Intake Air Low Pressure Switch Circuit Low Voltage |
Citroen | Catalyst Temperature Sensor Failure |
Daewoo | Egr Control |
Ford | Catalyst Temperature Sensor |
Gm | Intake Air Low Pressure Switch Circuit Low Voltage |
Honda | NOx adsorptive catalyst system – efficiency below limit |
Lexus | Evaporative emission (EVAP) system – small leak |
Lincoln | Catalyst Temperature Sensor |
Mahindra | Short Circuit To Ground Mil Lamp |
Mercedes-Benz | Secondary air injection (AIR) valve/solenoid – defective |
Mercury | Catalyst Temperature Sensor |
Peugeot | Catalyst Temperature Sensor Failure |
Saab | Fuel tank pressure control solenoid – circuit malfunction voltage high |
Subaru | Fuel tank vent valve -circuit malfunction voltage high |
Suzuki | Evaporative emission (EVAP) canister purge valve – mechanical fault |
Toyota | EVAP Canister Small Leak |
Volvo | Outside air temperature sensor – signal low |
Volkswagen | Secondary air injection (AIR) valve/ solenoid - circuit malfunction |
