P1413
Manufacturer Specific Definitions for P1413
Acura | Secondary Air Injection System Control Solenoid Circuit High Voltage |
Audi | EGR Differential Pressure Sensor Signal Too High |
Bmw | Pedal Position Sensor |
Citroen | SAI System Monitor Circuit Low Input |
Ford | Secondary Air Injection System Monitor Circuit Low Voltage |
Lamborghini | EGR differential pressure sensor signal high |
Land Rover | Secondary air injection (AIR) system, bank 1 – control valve open |
Lincoln | Secondary air injection monitor circuit -low input |
Mahindra | Egr Valve Jammed At Open Position |
Mercury | Secondary air injection monitor circuit -low input |
Peugeot | SAI System Monitor Circuit Low Input |
Saab | Secondary air injection (AIR) pump relay – open circuit/short to ground |
Volkswagen | EGR Differential Pressure Sensor Signal Too High |
We have not gotten around to publishing a technical guide specifically for P1413 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
