P1409
Reading P1409 on your car
P1409 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1409
AudiEvaporative emission (EVAP) canister purge valve - circuit malfunction
BuickEGR Vacuum System Leak
CadillacEGR Vacuum System Leak
ChevroletEGR Vacuum System Leak
CitroenEVR Control Circuit Malfunction
DodgeMisfire Adaptive Numerator at Limit
FordEGR Vacuum Regulator Solenoid Circuit Malfunction
GmcExhaust gas recirculation (EGR) systemmalfunction
GmEGR Vacuum System Leak
JaguarExhaust gas recirculation (EGR) solenoid
KenworthP1409 - EGR - Filtered air pressure high fault when air pressure is greater than a APV
Land RoverElectronic vacuum regulator
LincolnExhaust gas recirculation (EGR) solenoid -circuitmalfunction
MazdaElectronic vacuum regulator control – circuit malfunction
MercuryExhaust gas recirculation (EGR) solenoid -circuit malfunction
PeterbiltP1409 - EGR - Filtered air pressure high fault when air pressure is greater than a APV
PeugeotEVR Control Circuit Malfunction
VolkswagenEvaporative emission (EVAP) canister purge valve - circuit malfunction
We have not gotten around to publishing a technical guide specifically for P1409 yet.
